Question having trouble with ethernet connection
Aug 13, 2020
I recently got ethernet ran upstairs to my computer and upon booting the computer i get under the ethernet settings the network name , followed by "no internet" .
I have found a fix for this but it is only temporary and needs to be applied every time the pc is booted. this fix is restarting the router.
i have tried the following soloutions.
Disabled virtual ethernet profiles as well as my wifi card
Updated ethernet drivers to newest available firmware
run these commands in admin cmd - ipconfig /release ipconfig /renew
flushed dns
manually tried to use 1.1.1.1//1.0.0.1 as dns
changed from static to dchp vice versa.
this is what i get when i run ipconfig/all (mind i have a wireless network card installed)
any help would be appreciated
Host Name . . . . . . . . . . . . : DESKTOP-XXXXXX
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 00-D8-61-9D-D1-7E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : fdc0:6991:6c77:1:98a5:750c:50a3:701f(Preferred)
Temporary IPv6 Address. . . . . . : fdc0:6991:6c77:1:ad09:750e:8d1a:ea82(Preferred)
Link-local IPv6 Address . . . . . : fe80::98a5:750c:50a3:701f%2(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.1.27(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 13 August 2020 17:07:44
Lease Expires . . . . . . . . . . : 14 August 2020 17:07:43
Default Gateway . . . . . . . . . : 10.0.1.1
DHCP Server . . . . . . . . . . . : 10.0.1.1
DHCPv6 IAID . . . . . . . . . . . : 335599713
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-2E-7B-38-00-D8-61-9D-D1-7E
DNS Servers . . . . . . . . . . . : 10.0.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Local Area Connection* 9:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
Physical Address. . . . . . . . . : 00-16-EB-89-8E-4D
Wireless LAN adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
Physical Address. . . . . . . . . : 02-16-EB-89-8E-4C
Wireless LAN adapter WiFi:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7265
Physical Address. . . . . . . . . : 00-16-EB-89-8E-4C
IPv6 Address. . . . . . . . . . . : fdc0:6991:6c77:1:4912:4ce8:f6f9:58(Preferred)
Temporary IPv6 Address. . . . . . : fdc0:6991:6c77:1:54ca:e638:d9af:92a8(Preferred)
Link-local IPv6 Address . . . . . : fe80::4912:4ce8:f6f9:58%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.108(Preferred)
Lease Obtained. . . . . . . . . . : 13 August 2020 17:07:47
Lease Expires . . . . . . . . . . : 14 August 2020 17:07:47
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 352327403
DNS Servers . . . . . . . . . . . : 192.168.1.254
Lutfij
What sort of a distance is the Ethernet wire traversing from the point of origin to your machine's Ethernet port? You might want to state the make and model of your motherboard and scope out the BIOS version that you're currently on.
Make and model of your router? You will also need to see if the router has any firmware updates pending.
Aug 13, 2020
the ethernet wire is really not that long, maybe 5 meters. the connection , when it actually can connect after i apply the formentioned fix gets the full speed and low latency.
the motherboard in my rig is a b450 tomohawk max
the router is an EE smarthub with the fibre plan
i have checked to see if there are any firmware updates and it looks like the updates get automatically pushed to the router.
i am on a relatively recent bios update
