HBA Card Advice
PopeViper
Commendable
Jul 25, 2016
I was recently donated a server with the following specs:
Supermicro 2U Server (12x 3.5" Bays)
SAS826EL1 Chasis , expander backplane with 2x SAS connectors.
X9DRI-LN4F+ Motherboard
2x Intel Xeon E5-2670 2.6ghz 8 GT/s 20m Cache Eight Core CPUs
96Gb DDR3 ECC Reg Memory
12x 3.5" Trays
SIMLP-3+ IPMI Remote Access Card
2x 920w Power Supplies
I'm wanting to add this as a secondary Plex server. The server did not come with any type of RAID card. I don't plan on using RAID in the current configuration. I was wondering if anyone could suggest a good HBA, for a JBOD configuration.
I'm thinking of either ESX, or Server 2012 R2 with Hyper-V.
Thanks for any suggestions!
What is the part number on the backplane is it sas2-826EL1 or just sas-826EL1?
I think with that backplane it's ONLY designed to work with a RAID controller, you will either need to use single drive raid arrays or swap the backplane for a JBOD one.
Be very careful with this system! You will need to pick a card and check compatibility for the sas expander. The lower port on the backplane is for the HBA and the upper is a pass through for another backplane.
I can tell you a 3ware 9750-8i works with this backplane (RAID) and a perc H710 does not. Supermicro has a few LSI cards that would work fine for JBOD. 3ware probably has a few cards that work with this backplane and have a nice compatibility list to check.
This is probably your chassis part number: SC826BE16-R920LPB
thanks, a friend gave me a lsi9260. Based on your info, i researched, and do see i have it mis cabled.
My goal is to have individual drives, no disk groups, no RAID, as i'm utilizing other recovery options for this data, but when I go into the HBA to configure, it looks like I'm forced to build a disk group, which obviously i don't want.
i just need something that can register all the drives connected into the backplane
Usually with RAID cards like this the only way to get around the "must be in raid" is to create individual raid 0 for each drive.
Looks like that card does not have IT firmware which would operate in JBOD mode.
