HD 4670 vs 9800 gt low power in dell e520
babydevil05
33
pentium d 2.8ghz,
2.5gb ram,
dell e520 305w stock cpu
windows vista home basic &
dell 21" monitor....
9800 gt: http://www.newegg.com/Product/Product.aspx?Item=N82E16814162032
hd 4670: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102818
will the 9800 gt bottleneck my system????
if yes..............................................
will i get best from hd 4670 or with 9800 gt????
if no...............................................
will it play gta 4 in medium....
gta 4 is the coolest game eva..
babydevil05
33
but which one will i get more fps, 9800 gt or 4670??????
shubham1401
9800GT will give more performance overall.
Both will be bottlenecked by your CPU.
For GTA 4 both the cards are good enough. But the real problem is your CPU.
Even nice core 2 Duo's struggle to play GTA4.
I will suggest you to buy the 9800GT.
babydevil05
33
will it be a little bit overkill if it the 9800 gt is 1gb.....
the shop have 1gb only, at $115 (RM410).....
& how much $$ will i save if using 48w rather than 85w...
im a f'ing noob at this...
wakakakaka
