I'm putting together a new system and it's been a while since I've done this. Things have changed a bunch. I'm fairly settled on these components:
intel 2600k
asrock p67 extreme 6
hd 5770 (sapphire)
sonata IV case
The Sonata comes with a 620W power supply. The 5770 says it requires a 75W 6-pin PCI Express power connector. Does that get fed from the motherboard or the power supply. And if the power supply, does anyone know if that Sonata power supply will have that connector?
thanks!
intel 2600k
hd 5770 (sapphire)
sonata IV case
thanks!
