Hello community. I'm currently experiencing a very serious problem with my graphic card.
Problem:
I recently formatted my OS (Windows 7 Ultimate x64) and when trying to install Catalyst drivers everything works fine until I reboot. I get to the "Starting Windows" screen and after that it just shows a black screen or I get a BSOD with "atikmpag.sys" error. I installed the latest stable version, 12.10.
What I did:
I goggled around and found two common problems. Computer drivers outdated and problems with RAM cards. I then proceeded with updating all my drivers with Driver Genius and running a memory check with Memtest86+. All drivers where updated and Memtest86+ made 5 full passes showing no errors at all.
The only way to get back into Windows again, was too go to enter "Safe Mode" and uninstall the display driver on "Device Manager". Then I was able to get into Windows and it automatically installed Standard VGA driver, which is the only way for me to operate this machine and write down my problems in here.
I tried using older catalyst display drivers as 11.10 and the latest beta version 12.11. No success at all.
I also did a chkdsk on my hard drive, but again, no errors.
So any one of you out there knows some way to get my graphic card back up? Thank you.
Graphic Card Info: http://www.notebookcheck.net/AMD-Radeon-HD-6970M.43077.0.html
Computer Specs:
Problem:
What I did:
Computer Specs:
Summary
Computer Brand Name: CLEVO P150HMx
Operating System: Microsoft Windows 7 Ultimate (x64) Build 7601
Service Pack: Service Pack 1
Processor: Intel Core i7-2720QM (2200.0 MHz)
Motherboard: CLEVO P150HMx (Intel HM65 (Cougar Point) [B3])
Memory: 8 GBytes (Dual-Channel)
Hard Drive: Seagate ST9500420AS (476,940 MBytes (500 GB))
Optical Drive: Optiarc DVD RW AD-7700S (DVD+R DL)
Display Adapter: AMD Radeon HD 6970M [Clevo]
Audio Adapter: Intel Cougar Point PCH - High Definition Audio Controller [B3]
ATI/AMD Barts/Blackcomb/Victoria - High Definition Audio Controller
Network Adapter: JMicron Technology JMC250 PCI-E Gigabit Ethernet Adapter
RealTek Semiconductor RTL8188CE Wireless LAN 802.11n PCI-E Network Adapter
Monitor: AU Optronics B156HW01 V5
Battery: X51
Processor
CPU ID: 000206A6
Code Name: Sandy Bridge-MB SV
CPU Stepping: D1
CPU Platform: Socket G2 (rPGA988B)
Microcode Update Revision: 28
Core(s): 4
Thread(s): 8
Original Frequency: 2200.0 MHz
Current Frequency: 2993.1 MHz = 30.00 x 99.8 MHz @ 1.2310 V
CPU Core Temperature: N/A
L1 Cache: Instruction: 4 x 32 KBytes, Data: 4 x 32 KBytes
L2 Cache: Integrated: 4 x 256 KBytes
L3 Cache: 6 MBytes
CPU Thermal Design Power: 45.0 W
Motherboard
Model: CLEVO P150HMx
Chipset: Intel HM65 (Cougar Point) [B3]
Slots: 4xPCI Express x1, 1xPCI Express x16
PCI Express Version Supported: v2.0
USB Version Supported: v3.0
Super IO/LPC Chip: SMSC SCH5317
BIOS Manufacturer: American Megatrends
BIOS Date: 07/06/2011
BIOS Version: 4.6.4
Memory
Module Number: 0
Module Size: 2048 MBytes
Module Type: SO-DIMM
Memory Type: DDR3 SDRAM
Memory Speed: 666.7 MHz (PC3-10600)
Module Manufacturer: Nanya Technology
Module Part Number: NT2GC64B88B0NS-CG
Module Revision: 0
Module Serial Number: 1563764717
Module Manufacturing Date: Year: 2011, Week: 13
SDRAM Manufacturer: Nanya Technology
Error Check/Correction: None
Number Of Banks: 8
Number Of Ranks: 1
Device Width: 8 bits
Bus Width: 64 bits
Module Density: 2048 Mb
Module Voltage: 1.5 V
Minimum SDRAM Cycle Time: 1.500 ns
CAS# Latencies Supported: 5, 6, 7, 8, 9
Minimum CAS# Latency Time: 13.125 ns
Minimum RAS# to CAS# Delay: 13.125 ns
Minimum Row Precharge Time: 13.125 ns
Minimum Active to Precharge Time: 36.000 ns
Minimum Write Recovery Time: 15.000 ns
Minimum Row Active to Row Active Delay: 6.000 ns
Minimum Active to Active/Refresh Time: 49.125 ns
Minimum Refresh Recovery Time Delay: 160.000 ns
Minimum Internal Write to Read Command Delay: 7.500 ns
Minimum Internal Read to Precharge Command Delay: 7.500 ns
Minimum Four Activate Window Delay Time: 30.000 ns
Supported Module Timing at 666.7 MHz: 9-9-9-24
Supported Module Timing at 400.0 MHz: 6-6-6-15
Supported Module Timing at 333.3 MHz: 5-5-5-12
Auto Self Refresh: Supported
Extended Temperature Range: Supported
Extended Temperature Refresh Rate: Not Supported
On-die Thermal Sensor Readout: Not Supported
Module Number: 1
Module Manufacturer: Elpida
Module Part Number: EBJ21UE8BBS0-DJ-F
Module Revision: 8240
Module Serial Number: 3745343323
Module Manufacturing Date: Year: 2009, Week: 31
SDRAM Manufacturer: Elpida
Number Of Banks: 8
Number Of Ranks: 2
Bus Width: 64 bits
Module Density: 1024 Mb
CAS# Latencies Supported: 6, 7, 8, 9
Minimum Active to Active/Refresh Time: 49.500 ns
Minimum Refresh Recovery Time Delay: 110.000 ns
Auto Self Refresh: Not Supported
Module Number: 2
Module Revision: 0
Module Serial Number: 751629908
Module Manufacturing Date: Year: 2011, Week: 8
Number Of Banks: 8
Number Of Ranks: 1
Bus Width: 64 bits
Hard Drive
Drive Model: Seagate ST9500420AS
Drive Controller: Serial ATA 3Gb/s
Drive Serial Number: 5VJDBM4Y
Firmware Revision: 0002SDM1
Drive Capacity: 476,940 MBytes (500 GB)
Media Rotation Rate: 7200 RPM
Temperature: N/A
Cache Buffer Size: 16384 KBytes
Number of Cylinders: 16383
Number of Heads: 16
Number of Sectors: Unknown
Sectors Per Track: 63
Native Command Queuing: Supported, Max. Depth: 32
TRIM Command: Not Supported
Write Cache: Present, Active
S.M.A.R.T. Feature: Present, Active
Security Feature: Present, Inactive
Removable Media Feature: Not Present, Disabled
Power Management: Present, Active
Advanced Power Management: Present, Active
Packet Interface: Not Present, Disabled
Look-Ahead Buffer: Present, Active
Host Protected Area: Present, Enabled
Power-Up In Standby: Not Supported, Inactive
Automatic Acoustic Management: Supported, Active
48-bit LBA: Supported, Active
Raw Read Error Rate: 104/6, Worst: 99 (Data = 6577110)
Reallocated Sector Count: 100/36, Worst: 100
Power-On Hours/Cycle Count: 95/Always OK, Worst: 95 (Data = 4704)
Power Cycle Count: 99/20, Worst: 99 (Data = 1247)
Reported Uncorrectable Errors: 100/Always OK, Worst: 100
Command Timeout: 100/Always OK, Worst: 99 (Data = 65541)
Spin Up Time: 97/85, Worst: 97
Start/Stop Count: 99/20, Worst: 99 (Data = 1273)
Seek Error Rate: 71/30, Worst: 60 (Data = 166725726)
Spin Retry Count: 100/97, Worst: 100
Temperature: 37/Always OK, Worst: 56 (Data = 37.0 C)
Power-Off Retract Count: 100/Always OK, Worst: 100 (Data = 119)
Load/Unload Cycle Count: 87/Always OK, Worst: 87 (Data = 26260)
Current Pending Sector Count: 100/Always OK, Worst: 100
Off-Line Uncorrectable Sector Count: 100/Always OK, Worst: 100
Ultra DMA/SATA CRC Error Rate: 200/Always OK, Worst: 200
Optical Drive
Drive Model: Optiarc DVD RW AD-7700S
Device Type: DVD+R DL
Drive Serial Number: L639Y7D2qQfl
Firmware Revision: 1.03
Supported Disk Type (Read): CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Supported Disk Type (Write): CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Display Adapter
Video Card: AMD Radeon HD 6970M [Clevo]
Video Chipset: ATI/AMD Radeon HD 6970M/6990M (BLACKCOMB XT/XTX/PRO)
Video Memory: 2048 MBytes of GDDR5 SDRAM
Bus Type: PCIe v2.0 x16 (2.5 Gb/s) @ x16 (2.5 Gb/s)
Video BIOS Version: 013.010.000.011.039419
Memory Bus Width: 256-bit
Number Of Pixel Pipelines: 4
Number Of Unified Shaders: 480
GPU Temperature: 39 °C (102,2 °F)
Memory Clock: 150.0 MHz (Effective 600.0 MHz)
Audio Adapter
High Definition Audio Codec: RealTek ALC892
Audio Adapter: ATI/AMD Barts/Blackcomb/Victoria - High Definition Audio Controller
High Definition Audio Codec: ATi RADEON HDMI
Network Adapter
MAC Address: 00-90-F5-BF-87-57
Maximum Link Speed: 100 Mbps
Network Adapter: RealTek Semiconductor RTL8188CE Wireless LAN 802.11n PCI-E Network Adapter
MAC Address: E0-91-53-5C-37-38
Maximum Link Speed: 24 Mbps
Monitor
Monitor Name: AU Optronics B156HW01 V5
Serial Number: Unknown
Date Of Manufacture: Week: 1, Year: 2008
Max Vertical Size: 19 cm
Max Horizontal Size: 34 cm
Suspend: Not Supported
Standard Colour Space: Not Supported
Preferred Timing Mode: Supported
Default GTF Supported: Not Supported
Battery
Device Name: X51
Manufacturer Name: Clevo CO.
Unique ID: Clevo CO.X51
Chemistry: Lithium Ion
Designed Capacity: 76960 mWh
Full Charged Capacity: 60680 mWh
Wear Level: 21.2 %
Power Status: On AC Power
Current Capacity: 60680 mWh (100.0 %)
Current Voltage: 14.800 V
Time of this report: 24-12-2012 16:34:56
HWiNFO32.dll: 4.0.7.0
