hi.
i have a old 42 plasma that has dvi output.
i had it run with gtx 280 and fx580 and 9800 gtx and ps3.
the screen worked great until i got the hd 7850.
i install it on the pc and i can see the bios up then the windowsloading page
with bad resolution and then i can't see nothing, there is black screen
and the windows not even work i can tell because the teamviewer isn't start
and i also can't get to it from mstsc.
now if i get the dvi out, power on the pc, and give it to start and plug back the dvi
its work like any other card,
games on ultra and everything.
so for 2 months i am using it when every shutdown\restart i have to unplug the dvi
boot and plug it agen.
now with a regular pc screen everything working just fine..
so that was on a win8 pc
now i got new pc with everything new but with the same hd 7850
witch is 2 months old and i install win7 on it and there is
the exact same problem so oviecly its the gpu and nothing els..
when i put an nvidia card everything is working perfect.. on the big 42 screen..
any suggestions?
oh and by the way i forgot to mention that if the pc goes to sleep or turn of the screen the screen is never awake and the same thing is happening (new and old pc) so of course i disable sleep anyway and set the turn of the screen to never because it also makes the pc stuck
any suggestions?
