hd 7870 xt problems
fountainpen
73
my GPU was broken and my custom pc builder company send me a new one, it was a club 3d hd 7870 XT, but the one they send me was shorter than the on i had, and i thought it was a 7870, so i called them and they said it was a new smaller version of the XT, i plugged it in and i got around 6 fps lower at the games i play, is this really a XT? and how can i check it because my computer only shows AMD hd 7800
Without a picture of the new card it would be impossible to say for certain, but I would bet it's just a regular 7870 based on the performance numbers.
G
Guest
Guest
Graphics Card Manufacturer Powered by AMD
Graphics Chipset AMD Radeon HD 7800 Series
Device ID 679E
Vendor ID 1002
Subsystem ID E246
Subsystem Vendor ID 174B
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 015.030.000.002
BIOS Part Number 113-C4740107-S03
BIOS Date 2013/01/10
Memory Size 2048 MB
Memory Type GDDR5
Core Clock in MHz 975 MHz
Memory Clock in MHz 1500 MHz
Total Memory Bandwidth in GByte/s 192.0 GByte/s
This is what I see in CCC under information / hardware on my Sapphire 7870XT.
arrpee
rad666
362
That more than likely makes it a 7870 ghz edition. Definately not the same thing as a XT.
