Hi I recently just got a couple of HD 8570 2Gb gpu cards cheap to replace my old HD 4830 512mb.
I know these are OEM cards but I figure they should be better than the 4830 but with one card installed windows only rates them 6.9 where the 4830 was 7.4.
According to CPUZ the Core and memory are only at 300mhz each but MSI afterburner says the core is 700mhz and the memory is 980.
When I play ark survival the framerates are worse than the HD 4830 but the graphics look better.
Now my BIG question is how do I run them in crossfire? according to the amd site they can but there is no crossfire clip. I installed them both on my motherboard one into the pci x16 and the other into pci 2.0 so where do I go from here please??
ga 880ga ud3h
Phenom II x4 955 BE
3x2GB DDR3 2000MHZ Super Talent Ram
ga 880ga ud3h
Phenom II x4 955 BE
