HD Audio Cable
Doppelganger_1
46
Does it connect to the motherboard if I installed a sound card or do I connect it to the sound card itself?
Thank you for anyone who responds.
If you've installed a soundcard, and your motherboard already has onboard audio, connect your cable to the soundcard. Then you want to enable Windows audio settings for Playback to use the soundcard. You can get to those sound settings from the Control Panel or an icon in the System Tray. Also make sure you have installed the drivers for the soundcard for your version of Windows (best to get them from the manufacturer's official site.
If you have any other questions, then list your computer hardware and Windows version.
hd audio, being spdif? hdmi? what cable are we talking here?
if you have a soundcard, forget the onboard one, think of it as it never existed, if it is still detected, see if you can disable the onboard one
if the cable you mention is spdif, to the sound card, no mainboard onboard soundcard
if hdmi, the sound card is disabled basically, the sound is procesed and generated by the monitor or the tv you use to connect to speakers
- Intel Core i5 7600K Kaby Lake CPU
- MSI Pro Series B250 PC Mate Motherboard
- Kingston HyperX FURY 8GB Kit (2x4GB) 2400MHz CL15 DDR4
- EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition Graphics Card
- Samsung 850 Series 256GB SSD
- Western Digital Black WD1003FZEX 1TB 7200rpm 3.5” HDD
- ASUS SATA DVD RW 24x
- Cooler Master Hyper 212 EVO
- Corsair Carbide Series 100R Mid tower case
- Corsair CS Series 550w Modular PSU (CS550M)
- Windows 10 64 bit
Hd audio is written on the cable and was bundled with the front panel cables like the reset switch.
