[SOLVED] HD Audio Connection Question
keijzerchief
15
I’m using the B450M DS3H for my build, but could not find a HD audio port to plug in the HD audio cable from the front of my case. Should I use the F_Audio port instead? Thanks in advance
Yes, use the Front Panel Audio port which has 9 pins on the bottom left of the motherboard.
Page 16 number 10 in the manual. Be careful to insert it correctly. There is a missing pin on purpose so you don't connect it wrong.
