[SOLVED] hd audio panel
Haji13680201
Commendable
Apr 20, 2019
75
Tying pin four (Presence#) to ground indicates to audio hardware and software that Intel HDAudio ports are connected. That's what that motherboard cable is doing for you.
Thank you for your guidance. Therefore, it can be concluded that in cable Hd audio..., pins two and four should be connected with a short wire. it's true?
