Hi everyone-
So here's the deal.... I have a system built on an ASRock Z97 OC Formula inside an AZZA case (AZZA CSAZ-8000W to be specific). Built Aug 2015.
When I was building it, I connected the case's "HD AUDIO" cable to the motherboard's "HD_AUDIO 1" spot ... (I don't believe there is more than 1 or an "HD_AUDIO 2" but I just wanted to be specific). Then I used headphones with the "front port" (actually top of the case, front) where there are 2 USB 3.0 ports, a pair of audio ports, 1 for mic 1 for headphones, and then a pair of USB 2.0 ports. The sound was always great- and in fact, the motherboard supposedly includes "7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec), Supports Purity Sound™ 2 & DTS Connect" (pulled right off their website) ... The back of the motherboard has audio ports/jacks as well, and from the beginning they never worked as well as the "HD Audio" I would get from the top/front jack. --- I should state I have used headphones exclusively since I bought the computer. A few different kinds but always headphones. --- Anyway the rear has 5 port/jacks, with 5 colors (black, orange, pink, green, blue). There is also a noticeable gold metal "box" on the motherboard inside that says "PURITY SOUND 2". But the sound from the front jack was always very good, never had a problem, and pretty much I ignored the rear ports (I figured if I ever got a real "sound system" of speakers etc. I would mess with it.)
So my beloved blue heeler caught himself in the headphones cord the other day, and when he pulled, the cord didn't just disconnect from the front port, it seems to have broken the port internally. So I can no longer use it. I don't know if it's fixable but it doesn't seem to be something I can mess with...Pretty much out of commission..... But I have the rear "sound codec"! So I am now using the rear jack(s). Except it's not *nearly* as good.
The only one I can get any sound in the headphones is the green one, and it's much, much quieter than the previous front "HD Audio" jack. I thought that maybe I needed to go disconnect the cord from the case that connects to the "HD_AUDIO 1" jumper on the motherboard- that doesn't seem to have done anything. I also tried checking BIOS, the only audio setting I could find was something about Enabling HD Audio to the front port, it was set on Auto, i tried disabling it, still nothing. I am watching/listening to a Star Trek episode as I type this, and I have the volume at 44, and it's noticeably quiet, probably quieter than 10-15 previously.
I feel like there is something going on that I can't figure out. I thought, "do I need to buy a sound card, like back in the early 90s with MS-DOS etc?" ... but I have found threads on Google on this very forum that says the ALC1150 on the motherboard is going to be better than any sound card I could buy up to/around $50 bucks... (which is definitely more than I would have wanted to spend on a stupid problem, anyway.) Am I just screwed here? It seems to me that if I had HD Audio in the system to begin with, and it just stopped working to the front port, it should be able to work in the back port. Do I need to mess with a wire, or a setting, or something? Is it a motherboard or even windows software setting? OR am I screwed, it was a hardware issue, only available through the front jack, and need to buy a sound card now?
OK Thank you very much, this forum is always tremendously helpful. Thanks again for your time.
