I have a i7 4790K and I have two Samsung monitors. My question is how to support two monitor @1920X1080 (1 DVI and 1 VGA)
This is should be an easy question, connected both monitors ans set up to extend the current monitor. However, my VGA monitor doesn't shows.
The computer can identify each monitor, and can display on each single monitor. I set the DVI as master display. But the problem is when I connect them both, only the DVI shows, VGA port doesn't work.
The MOBO is ASUS Z97 maxmium hero.
thanks for any helps
