HD7950, screen and sound freeze with black and white lines
berkincolakoglu
I was playing CSGO last night, suddenly the screen turned into black and white lines. At the same time the sounds of game started to come freezy too. So I had no vision and audio. And then I had to force restart my PC from button of restart on the case. And when the Windows icon, loading thing came up, i had 2-3 lines with different colors, green, blue, red...
And then I re-restarted the computer, everthing worked fine, I had no colorful lines etc. So I rejoined the game and realized that some settings that I changed with the last boot, which ended with the problem, were not existing. I had my old crosshair for example, not that I changed. I could play the game max 3 minutes more. And then the same thing happened. Black and white lines with freezy sound...
Screen turned into this while playing: https://preview.ibb.co/cdqW46/20180111_000201.jpg
My pc specs:
CPU: Intel I7 7700K
MOBO: ASUS B250G
GPU: ASUS HD7950
RAMS: Hyperx Fury 2x4GB
HDD: Seagate 2TB
CASE: Thermaltake Commander MS-I
PSU: Case's PSU, 700W
Please tell me if you want to get more info.
Thanks for your replys.
I have seen problems like this before. Try uninstalling the card from the motherboard and boot using the CPU graphics. Let me know if this problem still happens
Latest posts
