I just received an HD7970 today, but it takes to 8 pin connectors, my power supply only supports 1 8pin and 1 6pin connection. It's a sapphire vaporx model and is likely overclocked out of the box. By default for reference the HD7970 uses a 6+8pin configuration, would I be able to use this with a 6+8pin plugged in until I get an adapter for it and just lack some of the OC performance?
I wouldn't think this would damage the card at all while I use it like this, the 8pin was probably only soldered in for some OC headroom.
I'm reading that the reference model of this GPU tops out at around 200watts, a single 6pin can forward 75w while an 8 pin can push 150w, which totals 225w. The 8pin if I'm correct (which I'm probably not) supports additional ground which would be my concern in terms of actually damaging the card by not using the additional 2 pins. Would I be safe if I were to downclock it a bit or not overclock it (that is, if it powers on in this scenario.)
