Dear all,
This is my 1st post.
You may already know what's my problem
(Post title says it all 😉 )
So, the power failure happened while I'm running chkdsk on the questioned hdd in my winxp (p4) pc.
It has 3 hdds (80gbx2 & 160gbx1). Both 80gbs are doing fine. Problem (extremely slow. some files read rate 300kbps) occurred on the 160gb drive.
Already done everything to fix it, without any luck. 🙁
1. Reset the partition table & create new ones with different sizes.
2. Change the sata port, changed sata cable/power cable.
3. Plug in to a different pc.
4. Tried fat32 & ntfs file formats.
5. Google search with relevant keywords.
See the attached screen shot. (hd tune read rate)
Read speed is fluctuating like crazy.
Is this happened to anyone before ? Any ideas ?? Any cure/fix ?
Thanks & best regards.
Nayana Sri.
Nayana Sri.
