Hello everybody!
As my case has the hdds on the other side (behind the MoBo tray, near the mobo's back side) it doesn't get much cooling.
I suppose normal placed hdd brackets get air from sort of 360°, plus are in the way of fans.
However in my case they only get some air through the front lattice from the 140mm fan.
There are 3 hdd holders, vertically.
I'll post some hdd temps when I get home. (about 50 C° the middle drive (gets some airflow), and 55ish C° the upper one which gets almost zero airflow.)
3 140mm front intake fans are in the case.
The hdds are samsung hd154ui 1,5 tb and some noname barracuda, both very old.
Im asking this whole question for these reasons :
I plan on buying 1 or 2 WD 2TB black hdds [strike]what[/strike] which are higher performance drives, therefore more heat. And one Samsung Sata 3 500gb mz-76e500E. So I'm quite worried about hdd temps.
What about hdd coolers? Efficiency? Price-value factor? Noise? If, recommended, would you please suggest a few?
