HDD died during low level formatting
ajax2010
Commendable
May 28, 2016
4
I killed my 1TB external hard drive by accident. It is a 9SF2A4-500 - Seagate Expansion 1TB USB 2.0 3.5-inch External Hard Drive. I was doing low level formatting (old school) i.e; writing random 0,1 in one pass when suddenly I got BSOD and computer started rebooting. But since then HDD is ruined, Diskimage does not detect it. Disk management detects it but can not perform any job on it. One time I was able to format it using AOMEI Partition Assistant 6. The job was done fine but computer still does not recognize it. When I plug in, it just spins and spins and spins . . . . . . and no sound from it. So for I have tried EaseUS Partition Master 9, MiniTool-Partition-Wizard-Pro-9.1, Paragon-Partition-Manager-Home-15 but all in vain. I appreciate any help.
Unless it's in perfectly dust free environment that could ruin it completely. If you think that had may be stuck you can try to just gently knock it on a table on the side opposite of contacts and or on contact side depending where the head is parked.
Luckily Seagate offered the firmware update and the the process completed successfully. Unfortunately no luck and the symptoms are the same. I am thinking may be head is stuck, should I open it?
