Field Value
ATA Device Properties
Model ID TOSHIBA DT01ACA050
Serial Number Z39T231HS
Revision MS1OA750
World Wide Name 5-000039-FF8D90849
Device Type SATA-III
Parameters 969021 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 976773168
Physical / Logical Sector Size 4 KB / 512 bytes
Buffer 23652 KB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 56
Max. PIO Transfer Mode PIO 4
Max. MWDMA Transfer Mode MWDMA 2
Max. UDMA Transfer Mode UDMA 6
Active UDMA Transfer Mode UDMA 5
Unformatted Capacity 476940 MB
Form Factor 3.5"
Rotational Speed 7200 RPM
ATA Standard ATA8-ACS
ATA Device Features
48-bit LBA Supported, Enabled
Automatic Acoustic Management (AAM) Not Supported
Device Configuration Overlay (DCO) Supported, Enabled
DMA Setup Auto-Activate Supported, Disabled
Free-Fall Control Not Supported
General Purpose Logging (GPL) Supported, Enabled
Hardware Feature Control Not Supported
Host Protected Area (HPA) Supported, Enabled
HPA Security Extensions Supported, Disabled
Hybrid Information Feature Not Supported
In-Order Data Delivery Supported, Disabled
Native Command Queuing (NCQ) Supported
NCQ Autosense Not Supported
NCQ Priority Information Supported
NCQ Queue Management Command Not Supported
NCQ Streaming Not Supported
Phy Event Counters Supported
Read Look-Ahead Supported, Enabled
Release Interrupt Not Supported
Security Mode Supported, Disabled
Sense Data Reporting (SDR) Not Supported
Service Interrupt Not Supported
SMART Supported, Disabled
SMART Error Logging Supported, Enabled
SMART Self-Test Supported, Enabled
Software Settings Preservation (SSP) Supported, Enabled
Streaming Supported, Disabled
Tagged Command Queuing (TCQ) Not Supported
Write Cache Supported, Enabled
Write-Read-Verify Not Supported
SSD Features
Data Set Management Not Supported
Deterministic Read After TRIM Not Supported
TRIM Command Not Supported
Power Management Features
Advanced Power Management Supported, Disabled
Automatic Partial to Slumber Transitions (APST) Disabled
Device Initiated Interface Power Management (DIPM) Supported, Disabled
Device Sleep (DEVSLP) Not Supported
Extended Power Conditions (EPC) Supported, Enabled
Host Initiated Interface Power Management (HIPM) Supported
IDLE IMMEDIATE With UNLOAD FEATURE Not Supported
Link Power State Device Sleep Not Supported
Power Management Supported, Enabled
Power-Up In Standby (PUIS) Supported, Disabled
ATA Commands
DEVICE RESET Not Supported
DOWNLOAD MICROCODE Supported, Enabled
FLUSH CACHE Supported, Enabled
FLUSH CACHE EXT Supported, Enabled
NOP Supported, Enabled
READ BUFFER Supported, Enabled
WRITE BUFFER Supported, Enabled
ATA Device Physical Info
Manufacturer Toshiba
Hard Disk Name DT01ACA
Form Factor 3.5"
Formatted Capacity 500 GB
Physical Dimensions 147 x 101.6 x 26.1 mm
Max. Weight 450 g
Average Rotational Latency 4.17 ms
Track-To-Track Seek 0.6 ms
Interface SATA-III
Buffer-to-Host Data Rate 600 MB/s
Buffer Size 32 MB
ATA Device Manufacturer
Company Name Toshiba Corp., Storage Device Division
Product Information
http://sdd.toshiba.com
Driver Update
http://www.aida64.com/driver-updates
