Question HDD loud grinding noise after power cut
Jul 2, 2019
7
Hi, yesterday my pc wasn't fully connected to my electrical outlet all the way. As a result, my pc abruptly shut down twice. This resulted in a loud, grinding noise whenever the hard drive reads or writes. The drive passes the S.M.A.R.T. test. Should I just get it replaced by warranty? also, do WD send refurbished or new ones back? Thanks.
WD BLACK 4TB WD4005FZBX
Jul 2, 2019
7
I never really noticed the noises before the power cut though, it seems this new noise has come due to it.
noise: https://vocaroo.com/7vKGsbrzlZ1
from 'Short Generic' test
Its louder in real life and the noise is new so i'm quite concerned - it seems that the power cut has damaged it, but I don't know if this noise is worrying or just normal.
