HDD not being Recognized - please help me!
Barnito10
42
Hi
for the past 3 days every morning when i turned my computer on it wouldn't boot up windows but instead go into the asrock bios menu because my hard drive wasn't being detected. So i would just turn my computer off and back on and windows would boot up normally. Today was no exception but windows doesn't boot up at all this time. It keeps taking me to the asrock menu. My hard drive doesn't show up, even if I try reinstalling windows my hard drive doesn't show up at all.
The hard drive does work because i tried it on a different computer and it worked perfectly without any issues. I tried a different hard drive on my current computer and it also wouldn't detect it. What could be causing this? Please help me, I want to avoid having to take it to the repair shop.
thank you
My motherboard: ASROCK H81M-DGS-R2.0
Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
When i turn my computer on i can hear the hard drive working, all the fans turn on as well.
I built this computer about 3 weeks ago probably
here is all the hardware:
ram:G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3
processor: intel 3 4150
graphics card: EVGA 750ti ftw
power supply: EVGA 500 B 80 PLUS BRONZE Certified 500W Active PFC ATX12V v2.31/EPS 12V v2.91 3 Year Warranty 100-B1-0500-KR Power Supply Intel 4th Gen CPU Ready
Looks like the SATA controller in your motherboard has gone bust. If you do not want to dish out on a new mobo, I suggest you get a PCI sata controller as a temporary fix if low on budget. You can get them on the cheap.
http://www.shop.bt.com/products/startech-com-2-port-pci-express-internal-sata-ii-controller-card-5D30.html?utm_source=google&utm_medium=ppc%20product%20search&utm_campaign=PLA%20|%20Shopping%20|%20All%20Products
Here is one for under £20. Also, reset bios settings to default and also update the bios firmware.
I doubt it is a power issue as that PSU should be capable of running that rig without much hiccup.
