I am using a 3TB seagate external HD Expansion
Lemme tell u exactly what i did . I downloaded Hard Disk Sintenel and it showed me that i have 16 bad sectors and its health is 74%. I used (HDD regenerator 1.7) and when i started the 'scan and repair' function , an error box appeared that said " Error access violation with some numbers starting with 0x74fec..... " .After that my hard disk is not showing up in "My COMPUTER" , its detected by the computer and the option to remove safely is shown too.
It shows me when i enter Disk Management That Its unallocated and its named as Disk 1 with a black long line and its seperated into two parts 2TB and 700MB . I also by mistake made a new volume which appeared as 2tb in 'My computer' and it was empty (My HD was fully loaded), I was scared so i deleted The volume .
I used partition find and mount but no use , I used Mini Tool Power Data Recovery which recovered for me the second part that i mentioned before which is 700MB .. And it recovered 80% from my Drive but it was Described as RAW , It was not arranged or in specific folders , all the videos where in a folder and all music where in another folder and pictures in another folder . All the files have no Name so i can find what video or music is that specific file. So i need to enter 30,000 files to check what is what .
I am using EaseUS Data Recovery Now and it will take long time to finish , so can u plz help me solve this problem or a program that can recover all my data's but with some sense and specific file name , i dont want Raw files .
I am sorry for this Leanthy thread but I need to say waht i did exactly and what happened exactly , Hopefully someone can help me .
Thanks
Thanks
