Hi, Yesterday I was adding an additional fan to my pc and then I decided to move my Hard Drive up a few spaces, since it was a little too close to the GPU for my liking. I had the computer open when I plugged everything back in and tried to test it. All of a sudden some thick black-Greyish smoke started coming from the hard drives SATA power connection (right on the “plug”, sorry I don’t remember the actual word for it) I quickly unplugged the hard drive and the pc. After, I disconnected the SATA power connections and inspected it, the whole thing was covered in melted plastic (mostly melted in the middle of the plug, from the PSU). My first thought was that the computer is dead, fried and ruined. Since my psu has I think 4 SATA power connection heads I covered the burnt one in electrical tape and then hooked up one of the other SATA power connectors. The HDD looked like it had some burn damage around the SATA power plugin, but I figured why not try and see if my pc still works somehow. After hooking everything back up (using one of the additional SATA connectors) it started up like I never even touched anything, the new fan I put in and everything worked fine. Should I be worried about anything burning again or about my PSU/HDD? I really don’t have the money for a new PSU or HDD so I was wondering if I need to do anything or replace anything. Everything works fine and there are no more plastic burning smells or smoke. Tested everything and nothing seems off, The HDD should be fine I think since it was only the SATA power connection that was possibly damaged not the actual data transfer connection. Thanks in advance. I built this pc myself for gaming and nothing was off for the past 6 months since it was put together.
Specs-
intel i5 6400 CPU (liquid cooled)
Asus STRIX AMD R9 390 GPU
Asus Maximus VIII MOBO
Toshiba 1TB HDD
700W Thermaltake RGB PSU.
Cooler Master Cosmos SE Case (Closed rear panel)
Specs-
Toshiba 1TB HDD
