hdd system partition is not accsessable.
Fatih_1
73
hi, i have a big problem. i've two Windows on my pc, and when i'm on second one, i want to play a game so i launched it and bsod appears. now i cant boot, accsess or display the contents of this partition - i can use normally other partitions of same disk. i can't Access on cmd even ubuntu live, but strangely , mini tool partitionwizard is showing all contents of the partition, but it can only Show - no repair or rescue how i can boot/rescue files?
is a bit risky, i would from ubuntu run fsck command, also i would mount the partition as read only, but if the partition is too messed up, it will just make the problem worse
try to find the procedure for both tasks on a ubuntu forum because i don't use ubuntu at all, but i do use linux and that is what i do
seeing the partition itself is having problems is very likely that the hard disk is having problems too, try to run gsmartcontrol, if it detects errors i would replace the hard disk after recovering the files from it
the problematic drive is N: also i can see and modify even rename drive contents via CMD in WinRE
