Greetings, everyone!
Last month I got a new desktop, which HDD is a Western Caviar Blue of 1TB.
Everything works fine with it, except that while I use After Effects or render with Sony Vegas, the disk usage goes up to 100% in the task manager.
Here's a few things I've tried so far:
- Disabled Superfetch & Windows Search
- Disabled BITS
- Ran chkdsk on Command Prompt
None of these seem to have worked, though again, the 100% usage only happens while using After Effects and while rendering with Sony Vegas (at 1080p60).
My specs are:
- Intel i5-6500 Quad-Core 3.2GHz
- Kingston HyperX Fury Black 8GB DDR4-2400MHz
- MSI Z170 PRO GAMING CARBON
- MSI GTX 1060 Armor V1 3GB
- Western Caviar Blue 1TB 7200RPM HDD
What do you think might be causing this? It's very annoying because while I use After Effects I can barely do anything else on my computer and when rendering with Sony Vegas, my computer goes unusable. It's bothering especially because I know for a fact that with these specs, the computer can multi task just fine.
Thank you in advance,
- Nervly
- Disabled BITS
My specs are:
- Nervly
