Batguerra Distinguished Jan 13, 2014 235 0 18,710 Mar 19, 2014 #1 I've installed the new amd driver and it causes an fail to install the hdmi audio error which makes me think if someone else is having the same problem? ANd If so, how do I fix it? My monitor sound is not working anymore plz help 🙁
Solution photonboy Mar 19, 2014 It's a common problem caused by AMD's drivers. I suggest: 1) Remove all drivers, then reinstall the latest, or 2) Remove all drivers, and install the last KNOWN WORKING drivers.
ikes9711 Honorable Nov 15, 2012 493 0 10,860 Mar 19, 2014 #2 Unless you are using an hdtv in a home theater setting as a monitor I would not recommend using hdmi audio. Upvote 0 Downvote
Batguerra Distinguished Jan 13, 2014 235 0 18,710 Mar 19, 2014 #3 I'm just trying to make it work, can I do smething to fix it? Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Mar 19, 2014 Solution #4 It's a common problem caused by AMD's drivers. I suggest: 1) Remove all drivers, then reinstall the latest, or 2) Remove all drivers, and install the last KNOWN WORKING drivers. Upvote 0 Downvote Solution
