Ok, this is super simple actually and I have had this happen before with a home theater system. So, you will need to replace the cable most likely, and once that happens and it still doesn't work, then other options will need to be looked at. If you would keep us posted on this please, I would appreciate it, and I do hope it is something as simple as replacing the cable.
