HDMI Dual monitor problems
Aug 18, 2018
Hello,
So my problem is ever since I had a power outage a couple days ago my dual monitors haven't been working. I had a GTX 1050 Ti and before the power outage, it was working just fine. I don't believe my GPU was fried or anything like that but who knows? I'm connecting my main monitor to my computer by the means of a DVI cable. My secondary monitor is connected to my GPU through a VGA cable to a VGA to HDMI adapter. When I just connect one monitor with either of my connection methods it works just fine, but when I have both monitors plugged in only my main monitor works(DVI connection). In display settings, it shows both monitors and my mouse can disappear into where I have the secondary monitor set up.
I have been googling a lot trying to fix it and I haven't found a solution. If you have a solution that you think may work, don't be afraid to tell me I'm not afraid to spend the time to try and fix this.
Thank you,
S1ant
Similar threads
