HDMI graphic card to VGA monitor ?
cdalias
I intend to have new graphic card like GTX 1050 , but new graphic card does not support VGA output anymore , but I have a monitor only VGA support . So what kind HDMI TO VGA converter or adapter I should use to connect VGA monitor .
If you have DVI-I then you can use a passive adapter. If you have DVI-D, then you need an active adapter. Last I saw, the entire Pascal line of GPU's does not have any analog (DVD-I) support at all. so you would need an active adapter, whether it's HDMI or DP or DVI-D to VGA is up to you.
^ unfortunately Polaris cards are the same.
I have no idea why the decision was made to remove native analog support from new gpu's.
You would have thought at least the lower end 1050 & RX 460 cards would have it as these are cheap upgrade cards ideal for older systems where VGA only monitors are still likely used.
Probably keeps costs down/profits up - only reason I can think of , unfortunately means the end user has to spend $10-20 on an active converter.
