Question HDMI Signal Not Detected Neither gpu or motherboard input work
Nov 19, 2020
5
Motherboard: ASUS Z390-p
GPU: gefore gtx 1050ti
So my computer has been running very well since Ive built it however today I ran into a problem
While playing a video game my screen went black and I got the HDMI signal not detected notification
So I restarted the comp but that didnt work
I then tried to plug he hdmi cable into the integrated gpu and that didn’t work
I tried a different hdmi cable and that didnt work
I even tried to plug the pc into a different outlet but to no avail
Everything is plugged in correctly
Nov 19, 2020
5
Remove discrete graphics card from computer first. Physically remove it.
With discrete graphics card present, integrated gpu gets disabled.
BTW - that cpu model are you using? There are models without integrated gpu too. Then video outputs on motherboard will not work.
its an I5 K... Forgive I cant remember the exact model off the top of my head
the integrated gpu has worked before. I tried what you suggested but that didnt work either. Im going to try a different monitor to see if thats the issue
Nov 19, 2020
5
Nvm the other monitor doesnt have an hdmi port
Nov 19, 2020
5
UPDATE: Im about 99% sure its water damage my pcei cable was wet and I accidentally spilt a cup of water from my desk onto my computer but I didnt think it was a big deal because I dried it, but thats me being an amateur
