hi all,
just got a small problem, i am wanting to run a hdmi cable from my gtx460 to my monitor as i am using dvi at the moment. the problem that i have found in the position of the hdmi port is clear but when trying to connect the hdmi cable it is slightly too wide with the plastic coating around it too my case.
I have a antec 902 v3, the hdmi port is about 4 mil away from the edge of the case lip by the rear expansion slot covers.
Because their is a slight lip on the antec 902 the hdmi cable will not fit as it is about 5-6 mil on the plastic coating, so without cutting out 2 mil of the hdmi cable or 2 mil of the lip on the antec 902 im not sure what to do.
does anyone have any ideas or does anyone know of a slim hdmi cable connection.
Thanks
Thanks
