Ok so My current monitor -
Fujitsu L20T-1 20inch 60Hz 1600x900
I have the gtx 1050ti installed and i am using a hdmi to vga convertor because my monitor only has a vga slot ..
The problem is that the display is fine .. but when i start a game and play it .. in between sometimes the screen goes black and it shows no signal and turns off ..sometimes when i again plug in the hdmi it works back ..but the issue happens .. happens only in terms of games .. not regular windows ..
The catch is that when i connect my 55 inch tv via hdmi it works perfectly no issues .. so the issue isnt in my gfx
Can it be a faulty convertor or my monitor?
my monitor worked flawlessly till the past week i had r7 250x and never faced any issue ..
