HDTV works but no Analog tuning with ATI HDTV Wonder with ..
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I have an P4 3.2 GHz win xp pro sp2 on ASUS p5ad2-e premium [bios v
1004] with Sapphire Radeon x850 XT and
300 GB SATA HD, as well as 4 IDE devices [2 DVD burners running at UDMa
4 & 2, and 2 IDE HD running at UDMA 5]. The machine is an ASUS P5AD2-e
premium, and the 4 ide devices are connected to the ide raid connector
[this board's default for this connector is standard IDE, and this is
the only connector to support 133 mode transfers]. I have all the
latest radeon drivers, as well as all of the latest hdtv drivers [as of
4/10/05] installed. HDTV works, tv fails to initialize. Running pc
check shows everything being ok, except questions marks about the 4 IDE
devices having DMA enable [all of whice show up as udma during boot
post]. In looking at windows device manager, the primary and secondary
ide's are set to dma as possible. Any suggestions on ways to correct
this.
I have the following drivers installed:
For Radeon: wxp-w2k-catalyst-8-121-050322a-022141c.exe
For HDTV Wonder:
mmc-9-1-0-0-dao-mdac.exe
hdtv-wonder-5-01_2026v2.exe
atiCDwiz.exe [for dtv decoder]
mmc-9-06-1.exe
and I have installed directx 9c (dxwebsetup.exe) as well as
remote-wonder-3-01-0-0-english.exe [which by the way, no longer seems
to load after having uninstalled and installed it a number of times.]
I have windows media player 10 installed as well as windows media
encoder 9.
Is quite frustrating - I would really like to get this to work. Could
this possibly be bad hardware? [I noticed on the physical unit the
silver box on the card had some light white substance across the metal]
I guess I shouldn't be suprised, I've had 3 machines with 3 different
ati tv products and with every single one, getting the tv part to work
has been the biggest hassle. If anyone can recommend a different tv
tuner card [even if by ati] I'm all ears as well.
Thanks,
George
ghadley_00@yahoo.com
A few things come to mind:
A.) Don't trust that ATI PC Check for hard drive DMA compatibility...it's
always wrong
B.) I might be tempted to move the CD/DVD drives to the standard IDE
controller
C.) What anti-virus program are you running? Try disabling it.
D.) Any anti-pop-up or firewall software? Try disabling them as well
E.) Did you install Intel's chipset drivers?
It may be that you have faulty hardware, but I'd consider that as a last
resort. ATI software is known to be buggy so you might have to play with it.
Was this a clean install of the OS?
Robert J. Salvi, Ambiance Acoustics
http://www.ambianceacoustics.com
San Diego, CA USA
(858) 485-7514
<ghadley_00@yahoo.com> wrote in message
news:1113274559.817578.20040@f14g2000cwb.googlegroups.com...
> Hi,
> this.
> For HDTV Wonder:
> mmc-9-06-1.exe
> encoder 9.
> Thanks,
> George
....one more thing, you might also post this to:
alt.comp.periphs.videocards.ati
San Diego, CA USA
(858) 485-7514
"R. J. Salvi" <rjsalvi@nospamambianceacoustics.com> wrote in message
news:uAI6e.760$Q_1.68@news-wrt-01.socal.rr.com...
> always wrong
> controller
> it. Was this a clean install of the OS?
>> Hi,
>> this.
>> For HDTV Wonder:
>> mmc-9-06-1.exe
>> encoder 9.
>> Thanks,
>> George
If you do a search on ati's website they have a fix for your problem.
> Hi,
> this.
> For HDTV Wonder:
> mmc-9-06-1.exe
> encoder 9.
> Thanks,
> George
