Head sink fan help
Jacobpara
12
Hey guys, I needed some help with my heat sink fan. I wanted to know what direction to face the fan to I can get the best cooling and how do I know how to put it in that direction. I'm new so I needed come help
Here's a pic: https://postimg.org/image/k7p8nk0bh/b39987ee/
You could possibly flip the fan in its bracket so it blows in the opposite direction, but it would be pretty inefficient trying to suck thru the fins as opposed to blowing thru them. I don't recommend it.
You sure it won't just clear the ram? I have a similar setup and layout, and it looks like you have the same space to work with
I agree. You do not have to remove the heatsink to fix it.
Shutdown..snap off the 4 clips that hold the fan to heatsink..put it on the other side.
It will take cool air from the front and blow it to the back fan (make sure that rear fan is blowing out, not in.
* MAKE SURE YOU STABALIZE THE HEATSINK WITH ONE HAND WHILE YOU DO ALL THIS *
i tryed but my ram gets in the way. is there a way to get it to blow out while still on that side
It worked! i had to take a stick of ram out then put it back in after but it worked! my CPUID is showing better cooling already! thanks bro
