Headphone Amp Need More Volume!
Lritchie
132
Hi Guys I currently have a pair of beyerdynamic dt 770 pro headphones 250 ohm but when using them on phone or PC very low volume can anyone recommend a cheap amp that will increase volume and quality
Thanks
fiio a3 would be ideal as it is the replacement for the e11 and the e11 worked fine with that headphone. you could maybe struggle through with an e6 but you will be maxing it out so i'd suggest just spending more and getting a stronger amp from the beginning like the a3.
