I just bought a new case (Fractal Design R5), swapped over all my computer components and everything was going fine until recently my headphones have been giving a constant buzzing/humming noise. I think it's linked to power supply interference.
The interference is present on both the front and back audio port. But it is definitely weaker in the back port.
I have a single, grounded cable from the wall to the PSU.
I tried to isolate the problem component by doing these steps:
Weirdly when I remove the PSU from the case and rest it on cardboard with everything but the graphics card plugged in the noise disappears. I tried resting the PSU on cardboard inside the case with nothing else touching the PSU but the interference is still there.
I think the motherboard may be the problem. I would be content waiting to buy a new one if I knew that would solve the issue, but I would also just rather fix the problem at hand so I don't have to suffer in the mean time.
Tomorrow I will transfer everything back into the old case to see if that fixes it.
Any advice is greatly appreciated!
I tried replacing the PSU with a brand new one, no change.
I unplugged everything non-essential (including the graphics card), the noise weakened but was still present (less power used = less noise?).
I even tried attaching just the old case's front audio port, no change.
My headphones work fine in another PC.
I detached the front audio port from the motherboard, no change the back port still gives interference.
I have reinstalled windows (for the fun of it ;_😉, no change (correct/up to date realtek audio drivers).
