If you are running windows 7 do this.
Right click on the speaker icon next to the time.
Click on playback devices.
A window will open showing you all of the audio devices connected.
Speakers:
Headphones:
Right click on headphones, and select as default audio device from the menu.
Use the same method to get sound back to your speakers if you have any by setting them as the default audio device.
If it does not work then the front panel audio leads may not be connected to the motherboard inside the case if it is a tower system.
So you may have to open up the case to check if it is the problem.
