Headphone Y splitter not picking up voice. Please help!
emerald_piggy
5
I have headphones with a microphone that has 1 output 3.5mm jack. My PC has a separate mic and headphone jack. So I bought a splitter cable off of amazon for like $5 that I plug my headphones into and it splits it. I plug it in and I can hear fine out of it but when I try to speak in discord nobody can hear me. I checked the sound settings and when I talk it doesn't pick up anything. This is the splitter I got https://www.amazon.com/Maeline-Female-Plated-Headphone-Splitter/dp/B00PYZ2BT4/ref=sr_1_5?ie=UTF8&qid=1502116458&sr=8-5&keywords=3.5mm+y+splitter. Any solutions? Thanks!
Maybe like he said it isn't meant for PC. However just from experience, it should most likely work.
I was looking at the headphones on Amazon and under "frequently brought together" it shows aux splitter.
https://www.amazon.com/Belkin-Speaker-Headphone-Audio-Splitter/dp/B000067RC4/ref=pd_bxgy_23_img_3?_encoding=UTF8&pd_rd_i=B000067RC4&pd_rd_r=A9XHBRJS4B0RGNK0DGKN&pd_rd_w=L2Jfv&pd_rd_wg=Udjvl&psc=1&refRID=A9XHBRJS4B0RGNK0DGKN
Compare it with what you purchased and see if anything is different. Maybe something about this splitter will be more compatible for PC use.
The problem is definitely the splitter because when I take the splitter out and plug my headphones straight into the mic jack it picks up sound fine, but if I have the splitter plugged into just the mic jack and my headphones plugged into the splitter no sound picks up is there a way I can fix this?
this is weird but I was fiddling with the splitter and I found out that if I plug the headphone side of the splitter into the mic jack and the headphone side of the splitter into the headphone jack it would register the sound but now I can't hear anything. I was looking in the sound settings and it basically registers both jacks as mics now.
