G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
When I plug my headphones into the headphone socket on my speakers (powered
stereo desktop set, work fine) I get a deep bass buzzing distortion even at
zero volume. If I increase the volume I also get high pitched feedback (a
bit like what you get on FM radio if the station isn't broadcasting).
Also, bizarrely enough, sound from the left speaker goes to the right
headphone & vice versa.
If I disconnect the speakers from the green jack on the sound card, and
unplug the speaker power from the PC, and plug the headphones directly into
the green jack, I lose the bass buzzing but still get the high pitch
distortion (but at least out of the right earpiece!).
It's not the headphones that are the problem; they work fine with my hi-fi,
and I've tried more than one set.
I have onboard nVidia audio on my XP home PC. I've tried adjusting the
settings in the nForce control panel but with no luck. I'm sure it must be
software as the speakers work fine.
Please can you help - my neighbours'll thank you for it!
Thanks, Cookie_365
Thanks, Cookie_365
