Headphones giving me very low audio quality.
SkyHax
5
Ok so this happened yesterday. Out of nowhere my headphones started giving me very low audio quality. When i wigle the wire that is at the headphone jack sometimes audio comes back and stays , but for no reason it sometimes cuts out and it goess low quality again after some times if i move the wire.
TECKIEMAN
38
right click on volume and click mixer volume then you should see your audio device click on the icon go to advance at the top and that should work this is for windows ps it may not work as if its low the settings dont help that much
SBMfromLA
Where do you have your headphone plugged in at? The front of PC or in the rear directly into the motherboard? You could try using a different port if you have one. If it clears up immediately, then you could say it's a bad port. If the sound messes up when you use the other port then it could be a bad cable on your headphones.
gamal learn
6
THAT HEADSET MUST ME CHECKED " CABLES" , IF THAT SET ARE EXPENSIVE OR HAVE A GOOD MEMORIES FOR YOU , YOU CAN REPAIRE IT , I CAN DO THAT FOR YOU IF YOU ARE HERE IN EGYPT , IF YOU ARE AT THAT OTHER PART OF WORLD YOU CAN FIND A SPECIALIST FOR REPAIRING IT , MAY MIC WANT REPAIRING TOO . MY RESPET TO ALL FRIENDS HERE ☺
