Headphones are often damaged due to accidents and unfortunate circumstances. Cats/dogs chew on them, we accidentally yank the cord, et cetra. You could learn to solder (DIY) through some youtube tutorial or google how to repair such a task. Or you could contact the manufacturer and ask for a replacement/repair, which obviously costs some sort of fee. If it works, that's good. I don't see headphones as a permanent investment. Most people on average use them anywhere from 1 to 4 years and then change to a different one. speakers are more enjoyable, but you mentioned your daughter going to school so i understand the situation.
but to answer "is there a way to fix this", the answer is yes. solder on a new plug. if you're not technical or...
