Headset mic and speakers not working at same time
Mystic_CS
11
I'm using bluetooth headset paired to my pc and the problem is that when I turn on sound recorder or anything like that, even in voice chat what works is my mic only, speakers won't work and as soon as I exit out of the sound recorded I'm able to listen to songs or anything else again.
I'm using Motorola Pulse Escape.
Thank you.
I have the same headset and the same problem. The sound comes out normal from the speaker, but if I use at the same time some application that uses microphone, the sound stops coming out of the speakers.
For example, by playing Fortnite, when I enter the game, the sound is normal for the speakers, but when I enter a group with more people where the microphone is activated, the sound is muted. The same goes for apps like Teamspeak. Or if I go on the sound setup screen, I leave the speaker as default, and play a background song, when I switch to microphone setup tab, instantly the music to as if the audio did not work at the same time as the microphone.
Windows 10 x64
(Obs.: On the smartphone I can only use the microphone headset at the...
Have you checked to see in sound management (if using windows) whether your speakers or sound is set as the default device?
First check that better to report your specs here when posting be better
Windows 10 Pro Build 17134
Intel i5-8400
Zotac GTX 1050ti
8gb ram
1tb HDD
CorsairVS 450
MSI Z370-A Pro
And yes headset was selected as default device as both Playback and Recording device. Headset's speakers work where there isn't any mic using app open but as soon as I get mic into use, speakers stop working.
Windows 10 x64
(Obs.: On the smartphone I can only use the microphone headset at the same time as the speaker in phone calls. If I try to record my voice on the device it is not recorded by the headset. )
