my headset has a single jack, pc two jacks , one for headphones one for microphones
i have bought a splitter cable to ( http://www.newegg.com/Product/Product.aspx?Item=9SIA39V2UW5352&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-VigLink2-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3821802&SID=ijm1zawhvy000aau00053 ) to attach my headset to both jacks, however when i do this the microphone only records the sounds my pc makes. is my only option buying an external sound card to fix this(wil it fix it at all)? if so can you recommend decent sound card for £40 or lower.
a last resort is that i buy this ( http://www.amazon.co.uk/U7-Soundcard-Integrated-Headphone-Amplifier/dp/B00CP53ML2/ref=sr_1_12?ie=UTF8&qid=1453247868&sr=8-12&keywords=external+sound+card ) it's just a bit too pricey. or will the separate headphone and microphone jack cause the same problem when i'm using a splitter cable from my headset to this?
