Question Headset that sound distant and realistic need help with what they're called
Mar 20, 2024
Hello! So back in 2016-2017 i had one friend who had those headset i think it was hyper x and his headset sounded distant/realistic where it felt like the person sining or when gaming sounded some meters away. I've never really been able to explain what i mean but i'm trying my best for you to understand. Also i had one friend back in 2018 who also had this unexplainable sound but he had steelseries arctis 5 or pro i can't remember. However i keep buying steelseries products to get this sound but i can't really get a similar one. Any thoughts?
My thoughts.....
There may be a number of options and methods.
Google "audio realistic sound distances"
Read a few links and the revise your Google search criteria using words and phrasing from the links that seem to be the closest to the effect that you are seeking.
For example:
https://www.reprtoir.com/blog/immersive-audio
https://www.linkedin.com/advice/0/what-techniques-can-you-use-make-sound-effects
Very likely you will be able to narrow down to both the words describing the effect(s) you require and the products (hardware/software) that support the required effect and necessary configuration settings.
Post accordingly.
