Heat Control Problem
Oct 5, 2018
I use my old notebook mostly at over 100C temperature. But when i restart and go to bios settings fan speed immediately increases and it sounds like a jet turbine. Then it cools the PC down in like 5 minutes. I have never heard it sound like that while using at such high temperatures. If it is capable of that why isnt working? How can i control fan speed (there is no bios option)?
Im having the same problemas as you do. I've tried installing SpeedFan, after you select your laptop's model, it detects your fan and gives you control of it. Ho0pe it works for you since id did not work for me. I've also read that some fans are plugged directly to laptops power source bypassing the motherbord. If that's your situation then you have no control over you laptop fan 🙁
wish you bests!
