I have noctua u12 redux cooler, it has long heat pipe that block's the glass from closing , can i cut it to reduce it or is there any solution??
That just killed about 25% of cooling capacity.I tried to grind down a heatpipe on a cooler that I had no use for. You can only grind surprisingly little off the end of a heatpipe, before you reach the hollow core, and the cooling fluid immediately evaporates.
I managed to grind down roughly 1 mm, before the core was breached. I have attached a picture of the cooler which shows the heatpipe after I cut away the tip, maybe you can use it for reference.
As you can see the heatpipe wall is thinner on one side, so it's hard to predict how much you can grind away
EDIT : The heatpipe appear a bit thicker in the image because it is a close up, but roughly 1 mm to work with where the pipe wall is thickest.
In your case I would be very hesitant to begin grinding down the heatpipe, as you gain very little and risk damaging the cooler instead.
