G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I just put in a new Chaintech FX5700 card, and now after about 10-20 min of
use the mouse becomes 'jerky', i.e., will not move smoothly across the
screen. Also, the screensave will be running, and then exhibit the same
start-stop activity. I started running my system with a side panel off the
case, and the problem goes away. So, the detective in me says "Old vidcard,
no problem. New card, case buttoned up, problem. New card, case open, no
problem."
My question is, can excessive heat cause this behavior? The card itself is
warm to the touch, and has 3 heatsinks on the back that are pretty warm. Any
help is much appreciated.
problem."
