Heat sync cpu fan.
Mongrel
168
Please link heat sync cpu fans (3-4 heat sync pipes) that can go on the following motherboard:
Gigabyte H110M-S2H
Thanks !
Many air coolers can fit on that socket. What's more important is the case width to accommodate sink/fan height.
You need to pay attention to what your case is and how much space you have.
This is a good one:
https://www.newegg.com/Product/Product.aspx?Item=9SIACFW57P5018
http://www.tomshardware.com/reviews/thermalright-true-sprit-140-direct-cpu-cooler,4923.html
https://www.techpowerup.com/reviews/Thermalright/True_Spirit_140_Direct/
I had the older True Spirit 120 BW on a hexa-core CPU and even with that the CPU always ran at good temps at idle and under load.
I7700.
You can get a Thermaltake Hyper 212 evo for about $30 and it is as good as you can get for the price as long as it fits in your case.Normally Newegg includes cooler height specs in their specs tab for a case.
Never heard of that CoolerMaster
It still must fit inside the case.
You will need to go to Newegg and look up your case to find cooler clearance and then check for coolers that fit.You can always look for one with good reviews even if you don't know what you want.
I have a artic freezer A32 which is really big.. so pretty much anything will fit in my case.
Latest posts
