Heatsink and Fan Mount for Socket 478 Need
madden95
26
I've got an old computer hanging around that has been having overheating issues and I've determined it's because the heatsink doesn't properly sit on the processor due to a broken clip on the mount. I was wondering if anyone knew where I could find a proper mount for my Socket 478 2.4 Ghz Northwood. Any links, suggestions or general advice would be greatly appreciated.
Thanks,
John Madden
I'm not sure about replacing a broken clip on the stock HSF. Check newegg and buy an entire new aftermarket hsf for cheap. If you live in Southern, CA, I have an old stock 478 HSF I let go for like $10.00 if I pay shipping. PM me.
http://www.newegg.com/Product/Produ...ption=socket 478 heatsink&bop=And&Order=PRICE
Mount not sure - new clip can't be found? or maybe someone who installed an aftermarket cooler and also bought a boxed 478 still has the entire stock hsf somewhere in the garage?
If purchase a new one, I don't even need to say about the usual Zalman, Scythe and Thermaltake - you already know.
Well.. yes, this option is more expensive, but still it is some sort of a solution - don't know what do you think about that, but here are some of them anyway:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118112 (this one will fit on 478, but for future use on 775 you'll need to buy an add-on separately)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118114 (this one has "brackets" for both 478 and 775 and 120mm fan)
Scythe's maybe (see lin to more of them - in specs see 478)?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010110574+50002108&name=Scythe+USA
Also previously the non-VX version of Thermaltake's Big Typhoon was 478 compatible - not sure about that now.
Or less expensive (and ususally noiser) solutions, such as:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835119077
exotic http://www.newegg.com/Product/Product.aspx?Item=N82E16835200029
