Heatsinks And Cpu Cooler
loggand
Commendable
Oct 22, 2016
7
Can you install a heatsink and a cpu cooler or just one and what is the difference?
Im a bit of a noob
You can install either or both. It depends on what type of cooler you want. The heatsink is the part of the cooler the fan attaches to on most conventional air coolers.
Is there a video showing installation of both?
That will depend on 1) the motherboard, 2) the cooler you have, and 3) the room in the case you have. Maybe you better list your system specs and explain what you want to upgrade to.
Case: Cooler Master MasterBox 5 Case Black Edition
Psu: Cooler Master 850W
Motherboard With Cpu: Z170XP-SLI - Intel Core i5 6600K
Cpu Cooler: Cryorig H7
Ram: Corsair Vengeance LPX 16GB DDR4 Memory Kit Black
Gpu: Gtx 970 Mini Itx
I have the gpu and the psu im upgrading the rest on that list
